Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 11
Disconnect the ribbon cable and set the shell aside. If you want to remove the plastic card reader, locate its two locking plastic tabs that hold the card reader to the shell, spread them, and lift the card reader off of the shell. If you want to remove the plastic card reader, locate its two locking plastic tabs that hold the card reader to the shell, spread them, and lift the card reader off of the shell.
  • Disconnect the ribbon cable and set the shell aside.
  • If you want to remove the plastic card reader, locate its two locking plastic tabs that hold the card reader to the shell, spread them, and lift the card reader off of the shell.
Desconecta el cable plano y coloca la carcasa a un lado.
Si quieres quitar el lector plástico de tarjetas, localiza las dos pestañas que lo mantienen sujeto a la carcasa, separa las pestañas y levanta el lector de tarjetas para quitarlo de la carcasa.
