Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 6
Use the Torx Screwdriver (T8 or T10) to remove the torx screw from the space behind the rubber foot. This screw has a security bit but most are able to remove it successfully with a normal Torx driver.
  • Use the Torx Screwdriver (T8 or T10) to remove the torx screw from the space behind the rubber foot.
  • This screw has a security bit but most are able to remove it successfully with a normal Torx driver.
Utiliza el destornillador TOR (T8 o T10) para quitar el tornillo torx que está debajo del pie de goma.
Este tornillo tiene un "pincho" en la punta, pero la mayoría de destornilladores torx son capaces de desatornillarlo.
