Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 43 guías que incluyan este paso.
Inglés
Español
Paso 6
Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable. Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case. There are four plastic clips above the DVD slot, and another above and to the left of the IR sensor.  These clips can be very difficult to disengage without prying.  They can also be difficult to re-engage during reassembly.
  • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
  • Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
  • There are four plastic clips above the DVD slot, and another above and to the left of the IR sensor. These clips can be very difficult to disengage without prying. They can also be difficult to re-engage during reassembly.
  • Reassembly Tip: Press down firmly on the tip of the top case above the location of each clip until you hear a snap to reseat them in their slots.
  • Reassembly Tip: The two center DVD clips will rarely snap back into place properly without help, and downward pressure will instead simply deform the frame around the DVD slot. Support the frame by inserting a plastic spudger into the DVD slot directly under the clip location until it is snug, then press down until you hear the snap.
No quites la cubierta superior rápidamente. La carcasa está unida a la placa lógica mediante un cable plano.
Levanta la parte trasera de la carcasa y mueve los dedos a lo largo de los lados, liberando la carcasa sobre la marcha. Una vez que hayas liberado los lados, es posible que debas mover la caja hacia arriba y hacia abajo para liberar el frontal de la carcasa superior.
Hay cuatro clips de plástico encima de la ranura del DVD, y otro arriba y a la izquierda del sensor IR. Estos clips pueden ser muy difíciles de desenganchar sin hacer palanca. También pueden ser difíciles de volver a conectar durante el reensamblaje.
Consejo de reensamblado: presiona firmemente la punta de la carcasa superior sobre la ubicación de cada clip hasta que oigas un chasquido para volver a colocarlos en sus ranuras.
Consejo de reensamblado: Los dos clips centrales del DVD rara vez se ajustarán de nuevo correctamente sin ayuda, y la presión hacia abajo simplemente deformará el marco de la ranura del DVD. Apoya el marco insertando un spudger en la ranura del DVD directamente bajo el clip hasta que se ajuste, luego presiona hasta que oigas el chasquido.
