Saltar al contenido principal
Inglés
Español
Paso 6
Place a suction cup near the bottom left corner of the phone. The edge there has slightly thinner adhesive. Pull on the suction cup with strong, steady force to create a gap in the seam. Insert an opening pick in the gap.
  • Place a suction cup near the bottom left corner of the phone. The edge there has slightly thinner adhesive.
  • Pull on the suction cup with strong, steady force to create a gap in the seam.
  • Insert an opening pick in the gap.
  • Depending on how old your phone is, creating this initial gap may be very difficult. Here are some things you can try if you're having trouble:
  • Repeat the heating and pulling process multiple times to soften the adhesive.
  • Use a playing card instead of an opening pick to insert in the gap.
  • Try heating and prying at a different location.
  • Use a Jimmy to make the initial entry. Be careful working with metal tools, as they will scratch the frame and chip the glass screen.
Insertar traducción aquí
