Saltar al contenido principal
Inglés
Español
Paso 5
Start by slowly pushing down on the plunger. The inside of the plunger is full of air at first, so a quick downward thrust initially will push that air out quickly and splash water all over you and your bathroom. If the plunger feels a bit stiff, you can run it under hot water to loosen up the rubber.
  • Start by slowly pushing down on the plunger. The inside of the plunger is full of air at first, so a quick downward thrust initially will push that air out quickly and splash water all over you and your bathroom.
  • If the plunger feels a bit stiff, you can run it under hot water to loosen up the rubber.
Insertar traducción aquí
