Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Before beginning disassembly,  turn off the printer and unplug the power cord. Open the front access door and remove any cards or cables present. Close the access door. Remove the paper tray.
Preparation
  • Before beginning disassembly, turn off the printer and unplug the power cord.
  • Open the front access door and remove any cards or cables present. Close the access door.
  • Remove the paper tray.
  • Remove the ink cartridges.
  • You may wish to install the Protective Part to prevent the ink tubes from drying while the cartridges are removed.
  • Open the printer cover using the finger holds on the sides.
  • Unplug and remove any cords present under the cover.
  • Remove the LAN port and EXT port caps (if present).
Insertar traducción aquí
