Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Paso 7
Next we need to remove the plastic layer that protects the power supply so we can access to the screws beneath it. Once all the screws are gone we can lift the metal frame by using a flathead screw and some leverage to unlock all four sides from the plastic case of the optical drive. Once all the screws are gone we can lift the metal frame by using a flathead screw and some leverage to unlock all four sides from the plastic case of the optical drive.
  • Next we need to remove the plastic layer that protects the power supply so we can access to the screws beneath it.
  • Once all the screws are gone we can lift the metal frame by using a flathead screw and some leverage to unlock all four sides from the plastic case of the optical drive.
A continuación necesitaremos quitar la plancha plástica protectora de la fuente de alimentación así podremos acceder a los tornillos que hay debajo.
Una vez todos los tornillos están fuera, podemos levantar el marco metálico utilizando un destornillador plano y hacer un poco de palanca para desbloquear los cuatro lados de la carcasa de plástico de la unidad óptica.
