Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Paso 5
First of all let's remove the power supply by removing the four screws. In the blue box you can see the large fan, which is in front of the power supply to make sure the temperature is kept as low as possible, and to protect the "Emotion Engine". Here's a closer look at the massive power supply. Here's a closer look at the massive power supply.
  • First of all let's remove the power supply by removing the four screws. In the blue box you can see the large fan, which is in front of the power supply to make sure the temperature is kept as low as possible, and to protect the "Emotion Engine".
  • Here's a closer look at the massive power supply.
Primero de todo vamos a quitar la fuente de alimentación quitando sus cuatro tornillos. En la caja azul podemos observar un ventilador grande, el cual está enfrente de la fuente de alimentación para asegurarse de mantener la temperatura lo más baja posible y para proteger el "Emotion Engine".
Aquí podemos observar con más detalle la enorme fuente de alimentación.
