Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Inglés
Español
Traduciendo paso 1
Paso 1
Whenever you use the spudger near the battery, be very careful not to puncture the battery. Slide the point of a spudger in the crevice underneath the black tape bridging across the battery and the motherboard. Slide the spudger along the crevice to pry up the tape from the battery side.
  • Whenever you use the spudger near the battery, be very careful not to puncture the battery.
  • Slide the point of a spudger in the crevice underneath the black tape bridging across the battery and the motherboard.
  • Slide the spudger along the crevice to pry up the tape from the battery side.
  • Carefully peel the tape from the battery and fold it out of the way.
Cuando uses el spudger cerca de la batería, ten cuidado de no perforar la batería.
Desliza la punta de un spudger en la hendidura por debajo de la cinta negra conectando la batería y la placa madre.
Desliza el spudger a lo largo de la hendidura para levantar la cinta del lado de la batería.
Con cuidado despega la cinta de la batería y dóblala para sacarla fuera del camino.
