Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 8 guías que incluyan este paso.
Inglés
Español
Paso 2
Apply a suction cup to the heated bottom edge of the back cover. Make sure you did not mistake the screen side for the back cover side. If your back cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere.
  • Apply a suction cup to the heated bottom edge of the back cover.
  • Make sure you did not mistake the screen side for the back cover side.
  • If your back cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere.
  • Lift on the suction cup with strong, steady force to create a gap.
  • Depending on how aged your phone is, this may take significant force. If you are having trouble, apply more heat and try again.
  • Insert an opening pick into the gap.
Aplica una ventosa en el borde inferior caliente del teléfono.
Si tu tapa trasera está muy agrietada, cubrirla con una capa de cinta de embalaje transparente puede permitir que la ventosa se adhiera.
Levanta la ventosa con una fuerza fuerte y constante para crear un espacio.
Dependiendo de cuán gastado está tu teléfono, esto puede tomar mucha fuerza. Si tienes problemas, aplica más calor y vuelve a intentarlo.
Inserta una púa de apertura en la grieta.
[* black] Apply a suction cup to the heated bottom edge of the phoneback cover.
[* icon_caution] Make sure you did not mistake the screen side for the back cover side
[* icon_note] If your back cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere.
[* black] Lift on the suction cup with strong, steady force to create a gap.
[* icon_note] Depending on how aged your phone is, this may take significant force. If you are having trouble, apply more heat and try again.
[* black] Insert an opening pick into the gap.
