Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Traduciendo paso 22
Paso 22
Double-check the fit and alignment of your new battery before sticking it down. Be mindful of the battery data cable and make sure it doesn't get pinched or trapped under the battery board. If your battery came with adhesive pre-installed on the bottom, flip it over and carefully peel away the liner to expose the adhesive. If your battery did not come with adhesive, apply a thin double-sided adhesive tape such as Tesa 61395 to keep your battery in place.
Battery installation
  • Double-check the fit and alignment of your new battery before sticking it down.
  • Be mindful of the battery data cable and make sure it doesn't get pinched or trapped under the battery board.
  • If your battery came with adhesive pre-installed on the bottom, flip it over and carefully peel away the liner to expose the adhesive. If your battery did not come with adhesive, apply a thin double-sided adhesive tape such as Tesa 61395 to keep your battery in place.
  • Carefully position the battery and set it into place.
  • Press and hold each cell firmly for 5-10 seconds to secure it to the lower case.
Comprueba el ajuste y la alineación de tu nueva batería antes de pegarla.
Ten en cuenta el cable de datos de la batería y asegúrate de que no se pellizque ni quede atrapado debajo de la placa de la batería.
Si la batería viene con adhesivo preinstalado en la parte inferior, voltéala y despega cuidadosamente el revestimiento para exponer el adhesivo. Si tu batería no viene con adhesivo, aplica una fina cinta adhesiva de doble cara comoTesa 61395 para mantenerla en su lugar.
Coloca la batería con cuidado y colócala en su sitio.
Presiona y mantén cada celda firmemente durante 5-10 segundos para asegurarla a la caja inferior.
