Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 17
The remaining two smaller battery cells each sit on a slightly raised portion of the MacBook's aluminum frame. Slide a plastic card all the way underneath the far left battery cell—which you already separated in the previous steps—and then insert it carefully between the remaining left-side battery cell and the MacBook Pro's aluminum case. Slide a plastic card all the way underneath the far left battery cell—which you already separated in the previous steps—and then insert it carefully between the remaining left-side battery cell and the MacBook Pro's aluminum case.
Separate the inner left cell
  • The remaining two smaller battery cells each sit on a slightly raised portion of the MacBook's aluminum frame.
  • Slide a plastic card all the way underneath the far left battery cell—which you already separated in the previous steps—and then insert it carefully between the remaining left-side battery cell and the MacBook Pro's aluminum case.
Las otras dos baterías más pequeñas se encuentran en una parte ligeramente elevada del marco de aluminio del MacBook.
Desliza una tarjeta de plástico por debajo de la celda de la batería del extremo izquierdo, que ya has separado en los pasos anteriores, e introdúcela con cuidado entre la celda de la batería del lado izquierdo y el marco de aluminio del MacBook Pro.
