Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Paso 37
Disconnect the first antenna cable by prying it straight up from its socket. Carefully slide your tweezers or the flat end of your spudger underneath the cable until it's near the socket, and then gently twist or pry up to disconnect it. Carefully slide your tweezers or the flat end of your spudger underneath the cable until it's near the socket, and then gently twist or pry up to disconnect it.
Disconnect the antennas
  • Disconnect the first antenna cable by prying it straight up from its socket.
  • Carefully slide your tweezers or the flat end of your spudger underneath the cable until it's near the socket, and then gently twist or pry up to disconnect it.
Desconecta el primer cable de la antena empujándolo directamente hacia arriba desde el zócalo.
Desliza cuidadosamente tus pinzas o el extremo plano de tu spudger por debajo del cable hasta que esté cerca del enchufe, y luego gíralo suavemente o haz palanca para desconectarlo.
