Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 2
There is a small black screw located in-between the vents. You will see two sections of tightly packed slots and on single slot somewhat separated. This is where the screw is located.
Locating Phillips Screw
  • There is a small black screw located in-between the vents. You will see two sections of tightly packed slots and on single slot somewhat separated. This is where the screw is located.
  • PLEASE BE CAREFUL WITH THIS SCREW AS IT IS VERY EASY TO BE ROUNDED OFF.
Hay un pequeño tornillo negro ubicado entre las rejillas de ventilación. Verá dos secciones de ranuras apretadas y en una sola ranura algo separadas. Aquí es donde se encuentra el tornillo.
TENGA CUIDADO CON ESTE TORNILLO YA QUE ES MUY FÁCIL SER REDONDEADO.
