Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 6 guías que incluyen este paso.
Inglés
Español
Paso 8
Use the tip of a spudger to pry the antenna cable tape up from the rear case of the iPad. Gently pull the antenna cable out of the way as you work along the piece of tape, to keep it from resealing. Gently pull the antenna cable out of the way as you work along the piece of tape, to keep it from resealing.
  • Use the tip of a spudger to pry the antenna cable tape up from the rear case of the iPad.
  • Gently pull the antenna cable out of the way as you work along the piece of tape, to keep it from resealing.
Insertar traducción aquí
