Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 6 guías que incluyen este paso.
Inglés
Español
Paso 7
Pull the wide tape toward the top of the iPad, applying constant force to release it from the antenna cable between it and the speaker. Slide the tip of a spudger through the gap between the wide tape and the antenna cable, to release the adhesive connecting the two. Continue pulling the wide tape until it is no longer covering the antenna cable.
  • Pull the wide tape toward the top of the iPad, applying constant force to release it from the antenna cable between it and the speaker.
  • Slide the tip of a spudger through the gap between the wide tape and the antenna cable, to release the adhesive connecting the two.
  • Continue pulling the wide tape until it is no longer covering the antenna cable.
Insertar traducción aquí
