Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 10 guías que incluyan este paso.
Inglés
Español
Paso 6
Pull firmly to slide the lower case towards the front edge of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case. Pull first at one corner, then the other. Pull to the side—not up.
  • Pull firmly to slide the lower case towards the front edge of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
  • Pull first at one corner, then the other.
  • Pull to the side—not up.
  • This may require a lot of force.
Tira de la caja inferior firmemente hacia el borde frontal de la MacBook (lejos del área de la bisagra) para separar el último de los clips que sujeta la caja inferior
Tira primero de una esquina, luego de la otra.
Tira hacia un lado, no hacia arriba.
[* black] Pull firmly to slide the lower case firmly towards the front edge of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
[* black] Pull first at one corner, then the other.
[* icon_caution] Pull to the side—not up.
[* icon_note] This may require a lot of force.
