Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 10 guías que incluyan este paso.
Inglés
Español
Paso 5
Lift the front edge of the lower case (the side opposite the display hinge) enough to slide your fingertips underneath and get a good grip on it.
  • Lift the front edge of the lower case (the side opposite the display hinge) enough to slide your fingertips underneath and get a good grip on it.
  • Two additional hidden clips near the middle of the cover should pop free at this point, if they haven't already.
  • Don't lift more than an inch or so, and don't try to remove the lower case yet.
Levanta el borde frontal de la caja inferior (el lado opuesto de la bisagra de la pantalla) lo suficiente como para deslizar tus dedos por debajo y conseguir una buena sujeción.
Hay dos clips adicionales escondidos en la mitad de la tapa que podría liberarse en este momento, si no lo han hecho todavía.
No levantes demasiado y no intentes remover la caja inferior aun.
[* black] Lift the front edge of the lower case (the side opposite the display hinge) just enough to slide your fingertips underneath and get a good grip on it.
icon_note] Two additional hidden clips near the middle of the cover mayshould pop free at this point, if they haven't already.
[* icon_caution] Don't lift very farmore than an inch or so, and don't try to remove the lower case yet.
