Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 78 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide or follow the abbreviated instructions below to disable Auto Boot. This command may not work on all Macs. Power on your Mac and launch Terminal. Copy and paste the following command (or type it exactly) into Terminal:
Disable Auto Boot
  • Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide or follow the abbreviated instructions below to disable Auto Boot. This command may not work on all Macs.
  • Power on your Mac and launch Terminal.
  • Copy and paste the following command (or type it exactly) into Terminal:
  • sudo nvram AutoBoot=%00
  • Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
  • You can now safely power down your Mac and open the bottom case, without it accidentally powering on.
  • When your repair is complete and your Mac is successfully reassembled, re-enable Auto Boot with the following command:
  • sudo nvram AutoBoot=%03
Antes de iniciar este procedimiento, debes desactivar la función de arranque automático de tu Mac. Auto Boot se enciende en tu Mac cuando abres la tapa y puede activarse accidentalmente durante el desmontaje. Usa esta guía o sigue las instrucciones abreviadas a continuación para deshabilitar el inicio automático.
Enciende tu Mac y ejecuta Terminal.
Copia y pega el siguiente comando (o escríbelo exactamente) en la Terminal:
Presiona [return]. Si se te solicita, introduce tu contraseña de administrador y vuelve a pulsar [return]. Nota: La tecla de retorno también puede estar etiquetada como ⏎ o "enter".
Ahora puedes apagar con seguridad su Mac y abrir la carcasa inferior, sin que se encienda accidentalmente.
Cuando hayas finalizado la reparación y se haya vuelto a ensamblar su Mac, vuelve a habilitar el inicio automático con el siguiente comando:
[title] Disable Auto Boot
[* icon_note] Before starting this procedure, you must disable your Mac's '''Auto Boot''' feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. [guide|110034|Use this guide] or follow the abbreviated instructions below to disable Auto Boot. ''This command may not work on all Macs.''
[* black] Power on your Mac and launch '''Terminal'''.
[* black] Copy and paste the following command (or type it exactly) into Terminal:
[* black] '''sudo nvram AutoBoot=%00'''
[* black] Press '''[return]'''. If prompted, enter your administrator password and press '''[return]''' again. ''Note: Your return key may also be labeled ⏎ or "enter."''
[* icon_note] You can now safely power down your Mac and open the bottom case, without it accidentally powering on.
[* icon_reminder] When your repair is complete and your Mac is successfully reassembled, re-enable Auto Boot with the following command:
[* black] '''sudo nvram AutoBoot=%03'''
