Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 16 guías que incluyen este paso.
Inglés
Español
Paso 22
Insert the tip of one last pick next to the previous step's pick, and slide it beneath the home button. Stop about an inch from the right-hand side to avoid cutting the digitizer cable. Insert the pick slightly deeper and work it back toward the home button.
  • Insert the tip of one last pick next to the previous step's pick, and slide it beneath the home button.
  • Stop about an inch from the right-hand side to avoid cutting the digitizer cable.
  • Insert the pick slightly deeper and work it back toward the home button.
  • Again, be sure to only slide the pick toward the center of the iPad when it is fully inserted; otherwise you may damage the antenna beneath the glass.
Insertar traducción aquí
