Saltar al contenido principal
Inglés
Español
Traduciendo paso 7
Paso 7
Note the shape of the hole under the replacement analog stick cap and how it matches the shape of the analog stick shaft. Orient them correctly for a proper fit. Take your new caps and push them into the shaft.
Install the New Caps
  • Note the shape of the hole under the replacement analog stick cap and how it matches the shape of the analog stick shaft. Orient them correctly for a proper fit.
  • Take your new caps and push them into the shaft.
  • Push the cap all the way down until you hear a ‘click’, which is the analog button being pressed.
  • Make sure that the analog shaft stays straight and centered while you are pushing down on the cap.
  • The replacement caps sent by 8BitDo seem to be a newer, better silicon-coated variant, instead of the old caps that used rubber.
Insertar traducción aquí
