Saltar al contenido principal
Inglés
Español
Paso 3
Use a spudger to pry the battery out from its compartment. The battery is secured by double-sided foam adhesive. Be gentle and take your time to avoid damaging the battery. Set aside the battery.
Remove the Battery
  • Use a spudger to pry the battery out from its compartment.
  • The battery is secured by double-sided foam adhesive. Be gentle and take your time to avoid damaging the battery.
  • Set aside the battery.
  • Be careful not to pull on the wires!
  • The ribbon that connects the analog board to the main controller board is now accessible.
Insertar traducción aquí
