Saltar al contenido principal
Inglés
Español
Traduciendo paso 1
Paso 1
This step shows how to drill a rivet out. Center a sharp 3/16" drill bit on the rivet head's indentation. Drill at slow to medium speed while applying steady pressure.
  • This step shows how to drill a rivet out.
  • Center a sharp 3/16" drill bit on the rivet head's indentation.
  • Drill at slow to medium speed while applying steady pressure.
  • Drill about 1/3" deep—enough to drill past the rivet head and into the shaft.
  • Use a center punch and mallet to tap the shaft away from the head. Remove the rivet head.
  • You may not be able to retrieve the rivet shaft. This is normal.
Insertar traducción aquí
