Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 8
Carefully note the pump direction indicated by the arrow on its label. The replacement pump must be installed in the same direction as the original. If you are working on the Wide Track model, determine which pump(s) you are replacing as well as their direction:
  • Carefully note the pump direction indicated by the arrow on its label. The replacement pump must be installed in the same direction as the original.
  • If you are working on the Wide Track model, determine which pump(s) you are replacing as well as their direction:
  • The front pump
  • The rear pump
Insertar traducción aquí
