Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 4 guías que incluyan este paso.
Traduciendo paso 4
Paso 4
Apply mild heat (with an iOpener, heat gun, or hair dryer) to soften the adhesive securing the home button gasket.
Using your fingertip, gently press up on the home button from the front side of the display assembly. Use firm, constant pressure to slowly separate the home button's rubber gasket from the front panel.
[* icon_caution] The rubber gasket surrounding the home button is very thin and tears easily. [* black] Apply mild heat (with an [product|IF145-198-2|iOpener], heat gun, or hair dryer) to soften the adhesive securing the home button gasket. [* black] Using your fingertip, gently press up on the home button from the front side of the display [* icon_caution] The gasket is very thin and will tear easily. Apply steady pressure and give it time to separate. |
