Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 6 guías que incluyan este paso.
Inglés
Español
Paso 7
Carefully lift the rear glass until you can reach the connector of the proximity sensor flex cable next to the rear camera assembly. Carefully lift the rear glass until you can reach the connector of the proximity sensor flex cable next to the rear camera assembly. Carefully lift the rear glass until you can reach the connector of the proximity sensor flex cable next to the rear camera assembly.
  • Carefully lift the rear glass until you can reach the connector of the proximity sensor flex cable next to the rear camera assembly.
Levanta con cuidado el cristal trasero hasta que pueda alcanzar el conector del cable flexible del sensor de proximidad junto al ensamblaje de la cámara trasera.
