Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Paso 2
In case you have trouble to pry up the battery the adhesive may not be loose enough. You can apply some isopropyl alcohol under each corner of the battery and allow it to penetrate for about two minutes to help weaken the adhesive. Try your best not to deform the battery during the following removal process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged. Do not use excessive force or pry at the battery with metal tools. Insert the flat end of a spudger at the top left corner of the battery and start to pry it up.
  • In case you have trouble to pry up the battery the adhesive may not be loose enough. You can apply some isopropyl alcohol under each corner of the battery and allow it to penetrate for about two minutes to help weaken the adhesive.
  • Try your best not to deform the battery during the following removal process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged. Do not use excessive force or pry at the battery with metal tools.
  • Insert the flat end of a spudger at the top left corner of the battery and start to pry it up.
  • Work your way down the left side of the battery and loosen the adhesive with the spudger.
En caso de que tengas problemas para sacar la batería, es posible que el adhesivo no esté lo suficientemente suelto. Se puede colocar alcohol isopropílico debajo de cada esquina de la batería y dejar que penetre durante unos dos minutos para ayudar a debilitar el adhesivo.
Intenta no deformar la batería durante el siguiente proceso de extracción. Las baterías de iones de litio de cáscara blanda pueden tener fugas de productos químicos peligrosos, prenderse fuego o incluso explotar si están dañadas. No uses fuerza excesiva ni hagas palanca en la batería con herramientas metálicas.
Inserta el extremo plano de un spudger en la esquina superior izquierda de la batería y comienza a hacer palanca hacia arriba.
Desciende por el lado izquierdo de la batería y afloja el adhesivo con el spudger.
