Saltar al contenido principal
Inglés
Español
Paso 5
We came overprepared with our Pro Tech Toolkit and its 64 driver bits—we only need one to twirl away these Torx screws and remove the midframe, along with its embedded earpiece speaker. On our way to the battery, we fold aside a couple of golden flex cables for the Active Edge sensors. In Pixels past, these cables were routed under the battery, out of sight and easy to destroy with wayward prying. It's nice to see them out of harm's way here. Onward to battery extraction, where two adhesive strips stand in the way. We locate the pull tabs and they cooperate without much fuss. Success! The battery is out.
  • We came overprepared with our Pro Tech Toolkit and its 64 driver bits—we only need one to twirl away these Torx screws and remove the midframe, along with its embedded earpiece speaker.
  • On our way to the battery, we fold aside a couple of golden flex cables for the Active Edge sensors. In Pixels past, these cables were routed under the battery, out of sight and easy to destroy with wayward prying. It's nice to see them out of harm's way here.
  • Onward to battery extraction, where two adhesive strips stand in the way. We locate the pull tabs and they cooperate without much fuss. Success! The battery is out.
  • This battery beats out the Pixel 3's 11.2 Wh battery with its own 11.55 Wh (3.85 V, 3000 mAh) powerhouse. That falls neatly between the iPhone XR and Samsung Galaxy S10e, at 11.16 Wh and 11.94 Wh, respectively.
Nos preparamos en exceso con nuestro kit de herramientas Pro Tech y sus 64 puntas para el destornillador. Solo necesitamos uno para girar estos tornillos Torx y extraer el marc medio, junto con el altavoz integrado en el auricular.
De camino a la batería, retiramos un par de cables dorados flexibles para los sensores Active Edge. En Pixeles pasados, estos cables se pasaban por debajo de la batería, fuera de vista y fáciles de destruir con una palanca indiscreta. Es bueno verlos fuera de peligro aquí.
Y adelante con la extracción de la batería, donde dos tiras adhesivas se interponen en el camino. Ubicamos las lengüetas y cooperan sin mucho problema. ¡Éxito! La batería está fuera.
Esta batería supera a la batería de 11.2 Wh del Pixel 3 con su propia central eléctrica de 11.55 Wh (3.85 V, 3000 mAh). Eso cae claramente entre el iPhone XR y el Samsung Galaxy S10e, con 11.16 Wh y 11.94 Wh, respectivamente.
