Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 4 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 2
Paso 2
Use the T5 Torx Screwdriver to remove both 2.5 mm screws from the battery cable. Use the Spudger to unstick the battery.
  • Use the T5 Torx Screwdriver to remove both 2.5 mm screws from the battery cable.
  • Use the Spudger to unstick the battery.
  • It's difficult to remove the battery without a pry tool like the spudger because of the strong adhesive. If you try removing it with just your fingers, the battery may bend.
Insertar traducción aquí
