Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 4 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
With the Zune facing down, as pictured, the battery ribbon cable is attached to the bottom right hand side of the logic board. Use the small flat head screw driver to gently lift the brown clamp.
  • With the Zune facing down, as pictured, the battery ribbon cable is attached to the bottom right hand side of the logic board.
  • Use the small flat head screw driver to gently lift the brown clamp.
  • The clamp will release the battery ribbon cable from the logic board, freeing the battery.
Insertar traducción aquí
