Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 16
Use a T8 Torx driver to remove the two remaining 4.9 mm hinge screws (one from each hinge). Remove the topmost screw last, using one hand to steady both halves of the MacBook Pro to make sure they don't separate and fall over unexpectedly. Remove the topmost screw last, using one hand to steady both halves of the MacBook Pro to make sure they don't separate and fall over unexpectedly.
  • Use a T8 Torx driver to remove the two remaining 4.9 mm hinge screws (one from each hinge).
  • Remove the topmost screw last, using one hand to steady both halves of the MacBook Pro to make sure they don't separate and fall over unexpectedly.
Utiliza un destornillador Torx T8 para quitar los dos tornillos de 4.9 mm restantes de la bisagra d (uno de cada bisagra).
Quita el último tornillo por última vez, usando una mano para sujetar ambas mitades del MacBook Pro para asegurarse de que no se separen y caigan inesperadamente.
