Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 11
Carefully remove the antenna assembly, while simultaneously feeding the antenna cable bundle out from underneath the heat sink. During reassembly, gently pinch the cable bundle together and guide it under the heat pipe into the correct position on the board. If needed, use your tools to help guide it through, but don't force it. During reassembly, gently pinch the cable bundle together and guide it under the heat pipe into the correct position on the board. If needed, use your tools to help guide it through, but don't force it.
  • Carefully remove the antenna assembly, while simultaneously feeding the antenna cable bundle out from underneath the heat sink.
  • During reassembly, gently pinch the cable bundle together and guide it under the heat pipe into the correct position on the board. If needed, use your tools to help guide it through, but don't force it.
Retira con cuidado el ensamblaje de la antena, mientras que simultáneamente saca el manojo de cables de la antena desde debajo del disipador de calor.
Durante el reensamblaje, aprieta suavemente el manojo de cables y guíalo debajo del disipador de calor hasta la posición correcta en la placa. Si es necesario, usa tus herramientas para guiarlo, pero no lo fuerces.
