Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Paso 16
Next we notice that the hinges, formerly bare, are newly covered in tape—probably to block debris from sneaking in through the pick-sized gaps in the outer spine. Dirt and debris can still get into the hinge and potentially gunk it up over time, but at least it will have a harder time making its way to the display. As we all know, anything lodged between the fragile display and its hard metal backplate can become a fatal pressure point.
  • Next we notice that the hinges, formerly bare, are newly covered in tape—probably to block debris from sneaking in through the pick-sized gaps in the outer spine.
  • Dirt and debris can still get into the hinge and potentially gunk it up over time, but at least it will have a harder time making its way to the display. As we all know, anything lodged between the fragile display and its hard metal backplate can become a fatal pressure point.
  • Enough staring at tape—let's rip it off and check out the hinges hiding beneath.
A continuación, observamos que las bisagras, antes descubiertas, se cubren nuevamente con cinta adhesiva, probablemente para evitar que los escombros se introduzcan a través de las aberturas del tamaño de una púa en la parte exterior de la columna vertebral.
El polvo y los escombros todavía pueden entrar en la bisagra y obstruir el engranaje con el tiempo, pero al menos la pantalla está fuera de su alcance. Por lo que sabemos, cualquier intruso entre la frágil pantalla y su placa protectora de metal rígida podría crear un punto de presión fatal.
Basta de mirar fijamente la cinta, vamos a arrancarla y a revisar las bisagras que se esconden debajo.
