Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Paso 15
Well, well—this must be the reinforced screen we've heard so much about. And we do indeed find an extra metal layer, like chainmail armor between the backing plates and the display. Backing the new notched armor layer are  the aforementioned metal support plates, whose edges are adhered to the phone's frame. This leaves the center spine free of adhesive for a wider-radius fold. All this metal makes the display surprisingly rigid, even when separated from the chassis.
  • Well, well—this must be the reinforced screen we've heard so much about. And we do indeed find an extra metal layer, like chainmail armor between the backing plates and the display.
  • Backing the new notched armor layer are the aforementioned metal support plates, whose edges are adhered to the phone's frame. This leaves the center spine free of adhesive for a wider-radius fold.
  • All this metal makes the display surprisingly rigid, even when separated from the chassis.
  • Once removed from the chassis, the display looks completely flat, with no fold or scoring in sight.
  • The "Advanced Polymer Protective Layer" on top of this flexible display—the one that caused all that ruckus before—is still not to be removed. But at least Samsung has removed temptation by extending it just about all the way to the edges of the screen.
  • We still can't believe that this layer wasn't hidden from the get-go. It looks so similar to the pre-installed screen protectors that ship with Galaxy S10 phones. Did they really think no one would pick at it?
  • We're guessing that removing this layer still kills the display, and since Samsung asked nicely, we'll leave it in place ... for now.
Bueno, bueno, esta debe ser la pantalla reforzada de la que tanto hemos oído hablar. Y de hecho encontramos una capa de metal extra, como una armadura de malla entre los platos de respaldo y la pantalla.
Como soporte de la nueva capa de armadura dentada están las placas de soporte metálicas antes mencionadas, cuyos bordes están adheridos al marco del teléfono. Esto deja el centro de la columna vertebral libre de adhesivo para un pliegue de mayor radio.
Todo este metal hace que la pantalla sea sorprendentemente rígida, incluso cuando está separada del chasis.
Una vez que se retira del chasis, la pantalla aparece completamente plana, sin arrugas ni pliegos visibles.
La "Capa protectora avanzada de polímeros" que se encuentra encima de esta pantalla flexible, la que causó todo ese alboroto antes, aún no se ha eliminado. Pero al menos Samsung ha eliminado la tentación extendiéndola hasta los bordes de la pantalla.
Todavía no podemos creer que esta capa no estuviera oculta desde un principio. Se parece mucho a los protectores de pantalla preinstalados que se entregan con los teléfonos Galaxy S10. ¿Cómo podrían haber imaginado que nadie querría dispararle?
Estamos suponiendo que la eliminación de esta capa aun sigue matando la pantalla, y como Samsung lo pidió amablemente, lo dejaremos en su lugar.... por ahora.
