Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Paso 17
Next up: the magic hinge that makes all of this folding wizardry possible, looking pretty similar to the last Fold we saw. Let's count it down: Four spring-loaded clasps lock the display in the "open" position. The system is well-engineered and likely to last a long while. Two hinges, secured to the spine—one at the top and one at the bottom—allow for some horizontal play in order to absorb any torsion force.
  • Next up: the magic hinge that makes all of this folding wizardry possible, looking pretty similar to the last Fold we saw. Let's count it down:
  • Four spring-loaded clasps lock the display in the "open" position. The system is well-engineered and likely to last a long while.
  • Two hinges, secured to the spine—one at the top and one at the bottom—allow for some horizontal play in order to absorb any torsion force.
  • One center hinge, which sports a gear system. This distributes the opening force equally, ensuring that the two halves of the phone open synchronously.
  • The two well-routed flex cables serve as a corpus callosum between the phone halves. Each end of the cable is held securely in place before the bend, giving the cable room to flex freely.
  • Routing flex cables through hinges is a serious reliability concern over the long haul. This one looks designed to hold up—but if it doesn't, at least the cable itself is modular, unlike some others we've seen.
A continuación: la bisagra mágica que hace posible toda esta hechicería plegable, con un aspectobastante similar al del último plegado que vimos. Hagamos una cuenta regresiva:
Cuatro cierres con resorte bloquean la pantalla en la posición "abierta". El sistema está bien diseñado y es probable que dure mucho tiempo.
Dos bisagras, aseguradas al lomo, una en la parte superior y otra en la parte inferior, permiten un juego horizontal para absorber cualquier fuerza de torsión
Una bisagra central, que luce un sistema de engranajes. Esto distribuye la fuerza de apertura por igual, asegurando que las dos mitades del teléfono se abran de forma síncrona.
Dos cables flexibles bien enrutados sirven como cuerpo calloso entre las mitades del teléfono. Cada extremo del cable se mantiene firmemente en su lugar antes de la curva, lo que permite que el cable se pueda doblar libremente.
El enrutamiento de los cables flexibles a través de las bisagras es un problema serio de confiabilidad a largo plazo. Este parece diseñado para resistir, pero si no lo hace, al menos el cable es modular, a diferencia de otros que hemos visto recientemente.
