Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Paso 14
Now bezel-less, the screen is primed for prying off! We didn't need any heat last time, but today it seems Samsung isn't taking chances—they want this screen to stay put, and have added an extra sticky strip of black tar goop. The screen is still adhered only along the outer edges—probably to allow the screen to float as it opens and folds. For once, the relative difficulty of replacing the screen is not even our biggest beef. You wouldn't even have to drop this thing to break it, meaning screen replacements seem inevitable, and that's a scary thought.
  • Now bezel-less, the screen is primed for prying off! We didn't need any heat last time, but today it seems Samsung isn't taking chances—they want this screen to stay put, and have added an extra sticky strip of black tar goop.
  • The screen is still adhered only along the outer edges—probably to allow the screen to float as it opens and folds.
  • For once, the relative difficulty of replacing the screen is not even our biggest beef. You wouldn't even have to drop this thing to break it, meaning screen replacements seem inevitable, and that's a scary thought.
  • Samsung generously offers to replace it for just $149—but only once, so make sure you use a light touch.
  • Granted, using plastic instead of glass as an OLED substrate means this display is less likely to shatter—but there are other modes of failure.
  • A single ultra-wide display cable connects the display to the board.
  • That means The Verge's reported "jelly scrolling" was probably due to the display driver software, not a split display.
  • Could they have updated the display driver for the second launch? Absolutely! Did we turn ours on to test before we took it apart? You ask too many questions.
¡Ahora sin bisel, la pantalla está lista para algunas maniobras (increíblemente sin calor)!La última vez no necesitamos calor, pero hoy parece que Samsung no se arriesga: quieren que esta pantalla permanezca en su sitio y han añadido una tira pegajosa extra de tela de alquitrán negro.
El ensamblaje de la pantalla solo está adherido a lo largo de los bordes exteriores, probablemente para permitir que la pantalla flote a medida que se abre y se pliega.
Por una vez, la relativa dificultad de reemplazar la pantalla no es ni siquiera nuestra mayor preocupación. Ni siquiera tendrías que dejar caer esta cosa para romperla, lo que significa que los reemplazos de pantalla parecen inevitables, y eso es un pensamiento aterrador.
Samsung ofrece generosamente reemplazarla por sólo $149, pero sólo una vez, así que asegúrate de usar un toque ligero.
El uso de plástico en lugar del vidrio como un sustrato OLED significa que es mucho menos probable que esta pantalla se rompa, pero hay otros modos de falla en esta pantalla.
Un solo cable de pantalla ultra ancha se conecta desde el lado izquierdo del teléfono.
Parece que el "desplazamiento de jalea"reportado por The Verge probablemente se deba al software del controlador de pantalla, no a una pantalla dividida
¿Podrían haber actualizado el controlador de pantalla para el segundo lanzamiento? ¡Absolutamente! ¿Prendimos el nuestro para probarlo antes de desarmarlo? Haces demasiadas preguntas.
