Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Paso 4
Did we mention it's thick? Folding phones are cool and all, but good luck fitting this thing into your skinny jeans. The hinge area packs the bulk of the, uh, bulk—partly because the screen doesn't fold completely flat. It closes more like a binder than a book, making contact only at the outer edge. Putting the fold on the inside rather than around the outside makes for a tighter radius and a whole different set of camera placement problems than, say, Huawei's approach with the upcoming Mate X.
  • Did we mention it's thick? Folding phones are cool and all, but good luck fitting this thing into your skinny jeans.
  • The hinge area packs the bulk of the, uh, bulk—partly because the screen doesn't fold completely flat. It closes more like a binder than a book, making contact only at the outer edge.
  • Putting the fold on the inside rather than around the outside makes for a tighter radius and a whole different set of camera placement problems than, say, Huawei's approach with the upcoming Mate X.
  • In its unfolded form, the main screen sports a slightly raised bezel, meaning there's a noticeable lip around the edges that you can feel under your fingers. This likely protects the display when it's folded or resting face-down on a table.
  • Word on the street is that scandalous screen protector now extends all the way under this raised bezel, away from prying hands. Will that protect it from us, though? Probably not.
  • The phone ships un-folded—but fold it even once, and that crease becomes pretty easy to spot if you're looking.
¿Mencionamos que es muy grueso? Los teléfonos plegables son geniales y todo eso, pero buena suerte con esta cosa en tus jeans delgados.
El área de la bisagra crea un grosor adicional, en parte porque las dos caras de la pantalla no se aplanan una contra la otra. Se cierra más como una carpeta de anillas que un libro, lo que lleva al contacto solo en el borde exterior.
El plegado de la pantalla en el interior en lugar de en el exterior conduce a un radio de curvatura más estrecho y a un conjunto de problemas completamente diferente en la disposición de las cámaras con respecto al, digamos, el enfoque de Huawei con el inminente Mate X.
En su forma desplegada, la pantalla principal muestra un bisel ligeramente levantado, lo que significa que puedes sentir con tus dedos un borde alrededor de los extremos. Es probable que esto proteja la pantalla cuando se pliega o se coloca boca abajo sobre una mesa.
Se rumorea que el escandaloso protector de pantalla ahora se extiende hasta el final bajo este bisel levantado, lejos de las manos entrometidas. ¿Pero eso la protegerá de nosotros? Probablemente no.
El teléfono se envía sin doblar, pero se dobla incluso una vez, y ese pliegue se vuelve bastante fácil de detectar si estás mirando.
