Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 3 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 5
Paso 5
Carefully lift the motherboard up from its edge and remove it from the tablet casing. While the camera is connected directly to the motherboard from the bottom and might lift out of the tablet with the motherboard, it also might not. In this case, as shown, you'll need to use the tweezers to pry the camera out of its spot. Removing the motherboard will reveal the top speaker that was being held down. If you are planning on replacing the top speaker, you may now simply pick it up out of the device.
  • Carefully lift the motherboard up from its edge and remove it from the tablet casing.
  • While the camera is connected directly to the motherboard from the bottom and might lift out of the tablet with the motherboard, it also might not. In this case, as shown, you'll need to use the tweezers to pry the camera out of its spot.
  • Removing the motherboard will reveal the top speaker that was being held down. If you are planning on replacing the top speaker, you may now simply pick it up out of the device.
Levanta con cuidado la placa madre por el borde y retírala de la caja de la tableta.
Aunque la cámara está conectada directamente a la placa madre desde abajo y puede que se levante de la tableta con la placa madre, también puede que no lo esté. En este caso, como se muestra, necesitará usar las pinzas para sacar la cámara de su sitio.
Al quitar la placa madre se revelará el altavoz superior que se estaba manteniendo presionado. Si está planeando reemplazar el altavoz superior, ahora puede simplemente sacarlo del dispositivo.
