Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Paso 8
Don't try to remove the motherboard all the way yet. The antenna cable is still connected to its rear side. Use a spudger to carefully lift the motherboard until you can get a good grip. Avoid to damage the cables next to the motherboard.
  • Don't try to remove the motherboard all the way yet. The antenna cable is still connected to its rear side.
  • Use a spudger to carefully lift the motherboard until you can get a good grip. Avoid to damage the cables next to the motherboard.
No intentes quitar la placa madre todavía. El cable de la antena sigue conectado a su parte trasera.
Usa un spudger para levantar cuidadosamente la placa madre hasta que puedas agarrarla bien. Evita dañar los cables próximos a la placa madre.
