Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Paso 2
Use the tip of an opening pick to pry up and open the black lever of the ZIF connector located on the bottom left of the motherboard. Use the tip of an opening pick to pry up and open the black lever of the ZIF connector located on the bottom left of the motherboard.
  • Use the tip of an opening pick to pry up and open the black lever of the ZIF connector located on the bottom left of the motherboard.
Utiliza la punta de una púa de apertura para levantar y abrir la manivela negra del conector ZIF situado en la parte inferior izquierda de la placa madre.
