Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 3 guías que incluyan este paso.
Inglés
Español
Paso 3
Slide an opening pick between the cover and the motherboard on the opposite side next to the SD card slot. Twist the opening pick to pry open the plastic clips securing the cover.
  • Slide an opening pick between the cover and the motherboard on the opposite side next to the SD card slot.
  • Twist the opening pick to pry open the plastic clips securing the cover.
Desliza una púa de apertura entre la tapa y la placa madre en el lado opuesto a la ranura para tarjetas SD.
Gira la púa de apertura para abrir las abrazaderas de la tapa.
[* black] Slide an opening pick between the cover and the motherboard on the opposite side next to the SD card slot.
[* black] Twist the opening pick to pry open the clamps ofplastic clips securing the cover.
