Saltar al contenido principal
Inglés
Español
Paso 11
The speaker is fastened to the case with small clips held down by two nuts.
  • The speaker is fastened to the case with small clips held down by two nuts.
  • Use a 5mm nutdriver to loosen the nuts.
  • You may find the space a bit tight to fit a nutdriver in close to the case edge. If so, you can try using needlenose pliers instead to loosen the nuts.
  • Once the nuts are loosened, you can separate the speaker from the case.
Insertar traducción aquí
