Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 3
Remove the single black Phillips screw from behind the display data cable.
  • Remove the single black Phillips screw from behind the display data cable.
  • Slide the small steel bracket away from the right clutch hinge and remove it from the clutch assembly.
  • If you have a Core 2 Duo Model A1211, there is no steel bracket. Simply remove the screw and continue to the next step.
Insertar traducción aquí
