Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Lift the inverter out of the clutch cover. Do not pull the inverter cable too far out of the clutch cover, as its ground loop is very fragile and easily broken.
  • Lift the inverter out of the clutch cover.
  • Do not pull the inverter cable too far out of the clutch cover, as its ground loop is very fragile and easily broken.
  • Disconnect the inverter cable from the inverter by pulling its cable away from the socket on the inverter board.
  • Remove the inverter and set it aside.
Insertar traducción aquí
