Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Paso 25
Remove all ten screws securing the logic board assembly: Two 2.6 mm T3 Torx screws
  • Remove all ten screws securing the logic board assembly:
  • Two 2.6 mm T3 Torx screws
  • Five 2.9 mm T5 Torx screws
  • One 3.7 mm T5 Torx screw
  • One 3.9 mm T8 Torx screw (large head)
  • One 4.0 mm T8 Torx screw
  • During reassembly, install these screws only loosely. Adjust the board position if necessary until all the connectors line up, and then tighten the screws.
Remueve los diez tornillos que sujetan el ensamblaje de la placa lógica.
Dos tornillos T3 Torx de 2.6 mm
Cinco tornillos T5 Torx de 2.9 mm
Un tornillo T5 Torx de 3.7 mm
Un tornillo T8 Torx de 3.9 mm
Un tornillo T8 Torx de 4.1 mm
Durante el ensamblaje, instala estos tornillos sin apretarlos. Ajusta la posición de la placa si es necesario hasta que todos los conectores se alineen y luego ajusta los tornillos.
[* black] Remove all ten screws securing the logic board assembly:
[* red] Two 2.6 mm T3 Torx screws
[* orange] Five 2.9 mm T5 Torx screws
[* yellow] One 3.7 mm T5 Torx screw
- [* green] One 3.9 mm T8 Torx screw
- [* light_blue] One 4.1 mm T8 Torx screw
+ [* green] One 3.9 mm T8 Torx screw (large head)
+ [* light_blue] One 4.0 mm T8 Torx screw
[* icon_reminder] During reassembly, install these screws only loosely. Adjust the board position if necessary until all the connectors line up, and then tighten the screws.
