Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 10 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 14
Paso 14
Follow this guide to reinstall the back cover and replace the adhesive.
  • Follow this guide to reinstall the back cover and replace the adhesive.
  • Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone.
  • If desired, you may reinstall the back cover without replacing the adhesive. Remove any large chunks of adhesive that might prevent the back cover from sitting down flush. After installation, heat the back cover and apply pressure to secure it. It won't be waterproof, but the leftover adhesive is usually more than strong enough to hold.
Sigue esta guía para volver a colocar la carcasa trasera y colocar nuevo adhesivo.
Asegúrate de encender el teléfono y verificar tu reparación antes de instalar el nuevo adhesivo y volver a sellar el teléfono.
Si lo deseas, puedes reinstalar la cubierta sin sustituir el adhesivo. Retira cualquier gran acumulación de adhesivo que pueda impedir que la cubierta esté nivelada. Después de la instalación, calienta la tapa y aplica presión para asegurarla. No resistirá el agua, pero el adhesivo normalmente es lo suficientemente fuerte como para aguantar.
[* icon_reminder] [guide|124003|Follow this guide|new_window=true] to reinstall the back cover and replace the adhesive.
[* icon_note] Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone.
[* icon_note] If desired, you may reinstall the back cover without replacing the adhesive. Remove any large chunks of adhesive that might prevent the back cover from sitting down flush. After installation, heat the back cover and apply pressure to secure it. It'''It won't be waterproofwaterproof''', but the glueleftover adhesive is usually more than strong enough to hold.
