Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 7
If you do not need to replace the front door control assembly I would not suggest to continue any further- That little spring took me a good 40 minutes to properly get back in place. It is Crucial to get it in right so that the Cassette door stays flush and closed. Find Door Spring and remove carefully. Then find and pry off (on either side) glued on bumpers- These limit the distance the door hinge can travel in order to be pulled off--- Find Door Spring and remove carefully. Then find and pry off (on either side) glued on bumpers- These limit the distance the door hinge can travel in order to be pulled off---
  • If you do not need to replace the front door control assembly I would not suggest to continue any further- That little spring took me a good 40 minutes to properly get back in place. It is Crucial to get it in right so that the Cassette door stays flush and closed.
  • Find Door Spring and remove carefully. Then find and pry off (on either side) glued on bumpers- These limit the distance the door hinge can travel in order to be pulled off---
Si no necesitas reemplazar el conjunto de control de la puerta delantera, no sugeriría que continues. Ese pequeño resorte me llevó unos buenos 40 minutos para volver a su lugar. Es crucial colocarlo
Encuentra el muelle de la puerta y quítalo con cuidado Luego, encuentra y saca (a cada lado) pegado a los parachoques: estos limitan la distancia que puede recorrer la bisagra de la puerta para poder extraerlos ---
