Saltar al contenido principal
Inglés
Español
Paso 2
Carefully insert your Mac OEM SSD as shown at left, with the golden contact pads below the connector pins facing upward. The SSD might take a significant amount of force to insert. Make sure you have the orientation correct before you apply any pressure. When the SSD is fully inserted, you should barely be able to see the golden contact points at the top of the drive, and the notch at the bottom of the drive should be aligned with the hole for the screw in the enclosure.
  • Carefully insert your Mac OEM SSD as shown at left, with the golden contact pads below the connector pins facing upward.
  • The SSD might take a significant amount of force to insert. Make sure you have the orientation correct before you apply any pressure.
  • When the SSD is fully inserted, you should barely be able to see the golden contact points at the top of the drive, and the notch at the bottom of the drive should be aligned with the hole for the screw in the enclosure.
Inserte con cuidado su Mac OEM SSD como se muestra a la izquierda, con los contactos dorados debajo de las clavijas del conector hacia arriba.
Es posible que la SSD requiera bastante cantidad de fuerza para insertarla. Asegúrese de tener la orientación correcta antes de aplicar presión.
Cuando la SSD esté completamente insertada, apenas debería poder ver los puntos de contacto dorados en la parte superior de la unidad, y la muesca en la parte inferior de la unidad debe estar alineada con el orificio para el tornillo en la caja.
