Saltar al contenido principal
Inglés
Español
Paso 3
Work your way around the edge shown here with your fingers until a crack appears. Then it should be easy to lift the bottom off. Be careful, The bottom is attached by a few wires. I nearly ripped these apart as I removed the bottom of the case. Be careful, The bottom is attached by a few wires. I nearly ripped these apart as I removed the bottom of the case.
  • Work your way around the edge shown here with your fingers until a crack appears. Then it should be easy to lift the bottom off.
  • Be careful, The bottom is attached by a few wires. I nearly ripped these apart as I removed the bottom of the case.
Insertar traducción aquí
