Saltar al contenido principal
Inglés
Español
Traduciendo paso 13
Paso 13
Next, we lift up the frame from in front of the TV (those tiny side screws did the work) and set it aside. Once done, lift up the glass section (carefully, it is glass) and replace it with a brand new glass screen! Make sure to match the right glass with the right TV, some of the glass can be a bit pricey (around $100 to $150) , but not as pricey as when someone else does it for you.
Screen removal
  • Next, we lift up the frame from in front of the TV (those tiny side screws did the work) and set it aside.
  • Once done, lift up the glass section (carefully, it is glass) and replace it with a brand new glass screen!
  • Make sure to match the right glass with the right TV, some of the glass can be a bit pricey (around $100 to $150) , but not as pricey as when someone else does it for you.
  • This is the end of this guide book!
Insertar traducción aquí
